Discuss Man cave earthing in the UK Electrical Forum area at ElectriciansForums.net
hi all I've got a man cave to get a supply to the earthing at the house is TNS, the man cave is steel frame, no spare ways in the house cu, it's a 30m run from meter to man cave, would you suggest a tt install or can I use the TNS, tt would be a pain to get the rods in ground as walls are underneath and ground full of Flint. Was going to split the tails at the meter I've already got swa in ground 3 core 16mm.
What would be best way for earthing in your opinion
I would use the TN-S. Splitting the meter conductors would you lose the single point of isolation.
Using the tns would save me a lot of hassle of trying to get a earth rod into the ground as it's solid. I was planning on putting a isolator next to where I split the tails for isolation.
Reply to Man cave earthing in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
