Discuss Masthead amp in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
the pict
Mentor
The above has gone phut in the meantime I have wago'd the coax and I get not a bad reception on most but not all channels, I have a powered booster inside so is that helping and is the replacement going to have to be the exact same, it is a vision 24Db V20-102 I cant see a direct replacement on the web so can I use summat else I have a complete aversion to all things AV etc so I need help
Pict
You should only need one booster for your signal, so you may find that if you just fit a shielded junction in place of the masthead you should have decent reception.
Otherwise if you signal is still weak (worth checking signal strength indication on your TV for each channel as you may have a strong but low quality signal which boosting will make worse) then you can use any type of masthead amp stick with the 24Db if you can but if you get one with variable gain then you can arrange the signal strength to suit.
Reply to Masthead amp in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hello, My sub panel is 100 amp (from a main of 200 amp) and it currently has a 20 amp 240 v breaker for A/C and then only lights and outlets...
Hi everyone. A DIYer here, not looking to fix this issue (as the house in question is hundreds of miles away...) but to try and help owner to...
4K
Hello, I have a set of cordless hair clippers that have a 18650 lithium ion battery inside. I popped it open and found 1 battery inside which is...
Ok Hello all and thanks for having me. I need some advice and joined this forum hoping to be pointed in the right direction. First off I am not...
4K
M
Ok. So split 1 house into 2. Was going to install a loftbox in both house, but couldnt get them to work. Have gone back to normal aerial amps...
