Discuss Maximum breaker size for DB (solar PV) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
Stengs
Hi,
Can anyone point me in the direction of the regulation / code for the max solar MCB size when connecting into a spare way of a local distribution board ?
Eg. Is it possible to connect a 100A breaker into a 100A board ?
I remember reading about the "20% rule" where pv breakers are limited to 20% of the array current on the load side, which doesn't seem right to me.
Say I have a 100A DB which has 80A connected load, one spare way. My PV mcb has to be 80A. Can I connect this safely as long as I'm below the 100A rating for the DB? Just can't find this in writing anywhere in the yellow book!
Reply to Maximum breaker size for DB (solar PV) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, this ones a first for me but weve been asked install and use a three phase supply in a large new build house. The 16 way dis board is...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Hi, I have a dual RCD board made by Hager installed a couple of months ago. It is high integrity, which I understand to mean RCBO’s can be...
4K
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Hi all, I have been asked to install individual three-phase supplies for a band saw and table saw. Having trouble figuring out the correct cable...
