Discuss mounting pv panels on slate roof in the Australia area at ElectriciansForums.net
I have just achieved mcs accreditation and have been asked to install a system on a slate roof. I am aware that some installers drill the slates and use sealed bolts to fix the mounting rails, I'm not overly keen on drilling someones slate roof and was wondering weather there is an alternative solution.
Did this last week- make sure you have roof hooks suitable for slate rooves. Remove the slates where the hooks will be. Cut the slates to fit around the hooks. Flashing both under the hook down to the slate below and flashing from the batten above down to the angle of the hook so that all screws are covered. Then fit slate cut to size.
Hope that made sense - in my opinion it's a much better solution than sealed bolts, especially as the customer will hold you liable for any leak over the lifetime of the system.
I'd advise getting a roofer in and have a contract stating that they are responsible for ensuring the integrity of the roof!
Reply to mounting pv panels on slate roof in the Australia area at ElectriciansForums.net
I spend a lot of time renovating vintage broadcast radios, military radio and test equipment. At present adding panels to our off grid...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Hi, Recently I had solar panels fitted and realised how they have done it and I hope someone will be able to give me advice how bad and dangrous...
4K
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
