Discuss Multimeter testing - help in the DIY Electrical Advice area at ElectriciansForums.net
The answer I have received from Fluke in case anyone interested:
The DC voltage function is a single 600.0V range specified at ±(1% of reading + 5 counts).
1% of 1.5 V is below the resolution of the range, leaving only 5 counts which is equal to ±0.5. ie the DC voltage function is accurate to ±0.5V
One possible explanation is that the Range has a small negative offset, Does the meter read 0.0 when the test leads are shorted ? (it does)
The instrument is reading within the published specification (±0.5V at 1.5V), there are no user adjustments to remove an offset.
in other words, the meter seems to be within spec. try it on a 9V PP3 or a 12V car battery.
Reply to Multimeter testing - help in the DIY Electrical Advice area at ElectriciansForums.net
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
The MS8268 multimeter has worked fine with no issues, but it's been in a drawer for several months. Batteries had corroded, but the contacts...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
So I have a outlet protected by a gfci breaker, and if you use the plug test the gfci doesn't trigger . I replaced the gfci breaker and the...
Hi guys. I posted yesterday about a suspected faulty starter motor.. I've had the starter out and cleaned everything up and all seems to be...
