Discuss Need some advice ! can I spur off a kitchen single socket that is coming off a fuse spur ? in the UK Electrical Forum area at ElectriciansForums.net
See appendix 15 for guidance. I'm assuming you are talking about spurred branches from a ring final.
Usual rules concerning cable CCC and circuit protection apply.
full
this diagram just about explains it all
The information given is a bit vague in regards to ‘coming off a fuse spur’.
What is the spur controlling? Is it an appliance or is it the installed socket? If it’s the later then yes you can extend the circuit, if it’s controlling an appliance then you can’t.
As andy78 mentions, read appendix 15 for guidance.
All the best,
Mike
Reply to Need some advice ! can I spur off a kitchen single socket that is coming off a fuse spur ? in the UK Electrical Forum area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
