Discuss No space for new CU. in the UK Electrical Forum area at ElectriciansForums.net
O
OldskoolUpNorth
Afternoon all,
Just got back from inspecting a domestic that is having a new CU installed.
Thing is, the DNO in all their wisdom have been out and fitted a posh new isolator as requested, FOR FREE, and put it in the only space big enough for a 17th board.
Now to the question,
Can a CU be mounted vertically?? i.e. On it's side. it's the only way it'll go in, and I don't think the guy will go for RCBOs and a smaller board just wi the cost of em.
Anybody ever fitted a CU vertical? or is it a big no-no.
Thanks as always.
I think I would just move the isolator. Anybody who looks at a CSU on its side, whether its right or wrong, is going to criticize it!
It would be a lot easier drew but I don't cut DNO applied seals, I know people do but thats up to them.
Otherwise I'd just of removed the main cut out in the first place.
it's compliant. think of a 3 phase boars, all the protective devices are mounted horizontally.
Unless the instructions for the CU state anything regarding positioning? Daz
It's acceptable to mount a consumer unit vertically as long as the main switch & circuit breaker 'on/off' positions are easily identifiable and circuit identification corresponds to the relevant OCPD.
According to Elecsa technical.
As mentioned, the main things are IP rating, function and identification. I would never do it, but I can't see a reason not to, as long as the above is ok.
exactly..as #3...
Reply to No space for new CU. in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Local funeral place is getting a new mortuary fridge unit, and needs some work done. The CU, just for the room, is high up in the corner, just...
Hi all, New homeowner here... hoping it's okay to seek some advice on a quote. I've recently had some wiring done for a new kitchen in a small...
