- Reaction score
- 768
But why are they not suitably fixed?What detriment can happen?They look pretty fixed to me.Where is the regulation stating that earth bonding wires have to be fixed separately from the pipe?
Discuss One way of earthing the pipes..... in the UK Electrical Forum area at ElectriciansForums.net
You all seem to be dissing my tie wrapping the bonding wires but how would you take the wire across and support it? I can still see no practical reason why i cannot do it as i have done.Just because someones NIC bloke says you can't doesn't make it law.If any of the other posts of inspectors is to go by they seem to make it up as they go along.
I've a question based on OP photo of completed work. The new CU is installed on ply. I recently had my registration visit from my chosen CPS and the guy who came wants the CU I installed to be practically air tight.
I had a garage install with 2 x 2.5mm T&E and 1 x 1.5mm T&E installed down wall in trunking to CU. I channeled the wall out to allow back entry into the CU. The gap between CU and block wall is about 5mm. The inspector told me that it was not good enough and that I should be filling the gap with intumescent foam to prevent air getting into the CU and help fuel a fire.
Now I stood there sort of bemused and wanting to really argue it but thought for a second and asked about IP ratings of CU and if the front of the board should be sealed as the gaps between the MCBs would also be a violation. He was quite adamant about it and was stating that it all changed with amd 3.
Now OP has installed a CU on a flammable material, I wonder what my guy would have to say about that???
If you can be arsed, I would be tempted to email your CPS with a general technical question regarding the 'sealing' of A3 CU's with intumescent materials.
When the replies comes back, stating there is no requirement other than maintaining IP ratings, you could then respond with your Assessment experience, and ask them to comment on that.
It should be noted no IP ratings are given for the rear of a dist board as it is assumed it will be fitted direct to a flat surface and not raised away from it.
Sneaky
Doesn't the general rule for live parts inside enclosures apply? IPXXB / IP2X (416.2.1)It should be noted no IP ratings are given for the rear of a dist board as it is assumed it will be fitted direct to a flat surface and not raised away from it.
Reply to One way of earthing the pipes..... in the UK Electrical Forum area at ElectriciansForums.net
