Discuss Outdoor IP68 Joint Boxes in the Electrical Tools and Products area at ElectriciansForums.net
Midwest
I'm installing some outdoor lighting (in my garden). Run some swa to Wiska boxes. I intend to go from there with some TRS flex close to each light. The lights I've have are sealed, with 1.5m of flex, so I will have to extend the flexes. Was going to use some small Wiska boxes etc to do this, but they will take up to much room, so I was considering using something like this;
https://www.amazon.co.uk/dp/B07Q29MY8M/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B07Q29MY8M
Has anyone used anything like this or have other recommendations?
Not with a great deal of success! I would suggest using something like link below and filled with gel.
Incidentally how far are they being extended and what mechanical protection are you providing?
Have you used the ones I posted?
About 2m. They will be run in a raised bed, which once the plants have been added, will have little regular gardening. Was thinking of running the flexes in some 20mm flexible conduit, just to keep them out of the way.
Had thought of using some NYY-J cable, but thought that was over egging it a bit, and would need different JB's?
Whats the voltage?
I never have any mains voltage for low level garden lighting, saves so much hassle..
Last job I done I also used pratley boxes as the previous attempt had used Wiska boxes and they had miserably failed but they were buried below ground, mains voltage and constantly tripping..
Yes used those but as said not with a great deal of success. (Not when used for IP68 protection!).
The NIC picked up on a garden installation we did a few years back in that the flexible conduit we used offered no mechanical protection and that we should use 'earthed plastic sheathed metal flexible conduit' for similar applications in the future!
Bit of an overkill in my opinion!
Whats the voltage?
Extra low. I'm going to use some Collingwood GL016 ground lights, in a wall, for step lighting!
Tried them out with their non IP rated driver, which I was going to house in a Wiska box. From the comments here, think I'll use their IP rated drivers.
Somewhat controversial, the other lights I'm gonna put in are Philips Hue Lily's, so just using their cabling, might try and squeeze them into some flexible conduits as well.
I'm not letting the NIC anywhere near my garden :)
No as said gone for the Philips Hue, and other low voltage lighting. Anyways, would still have the problem extending the Collingwood lights.
Reply to Outdoor IP68 Joint Boxes in the Electrical Tools and Products area at ElectriciansForums.net
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
I currently have some 12v outdoor lights which have a plug with a built in transformer. I would like these to turn on and off without having to...
Hi, I am a basic DIY'er, with basic electrical skills, NB, I can change a plug/fuse, change a ceiling light fitting, change a socket face plate...
