Discuss Outdoor sockets. in the Electrical Tools and Products area at ElectriciansForums.net
Why doesn't anyone make an outdoor socket that can take and plug with a transformer in it, a single socket I mean.
All the single sockets I see can only take a mains plug.
Maybe a business opportunity for someone I dunno but has anyone seen one?
A single socket capable of receiving a plug with a transformer built onto it and IP rated.
know what you mean. i've had a few jobs where had to fit socket and tranny in a IP55 box.
yes i second that as i went to get mk then realised no way was the lid shutting on the ones with transformer especially as the cable was coming out the top of the plug/transformer
so i was talked into buying these adaptable boxes that are for single or double and you can jsut fit a socket or fcu whatever direct slightly larger than MK type
bought a different set of robus decking lights ELV seperate transformer
connected everything up swa the lot only to realise that the moulded plug were the cable strain relief is is to big stopping the lid shutting correctly
Out with the hack saw and file and adapted to suit there is a inner lining that was catching the strain relief of the plugs havnt touched the outside so IP rating maintaned i hope lol
i nearly took em out and drove back to wholesalers to throw at him lol
MK also make large masterseal enclosures, should be large enough to take the plug in trannys with thier masterseal socket, but you'd have to use a compression gland to exit the cable and maintain the IP rating
Reply to Outdoor sockets. in the Electrical Tools and Products area at ElectriciansForums.net
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi, My first post so hopefully I am correct in posting it here. My question is, I am thinking of an IP rated outdoor socket for the back garden...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
