Discuss Outside light switch in the DIY Electrical Advice area at ElectriciansForums.net
R
rickBeyers
Hi all
looking for a bit of advise on an outside light switch. It was covered by a blank socket plate. There's a few wires in there and was wondering which goes where as it keeps flipping the rcb.
how do you know that that is the problem?
Sorry may not be the problem. Just when connected to the light spur and when switched on. The down light fuse flips. I'll check the actual light unit tomorrow when it's light. Was like this when I moved in so was just covered up as a quick fix I think.
it's either a fault with the wiring or you've connected it wrong. need to call in a local electrician who will have the necessary equipment to identify which wire does what.
Reply to Outside light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
