Discuss Portable Generator Receptacle in the UK Electrical Forum area at ElectriciansForums.net
FrankF
Hello, I am a DIYer and I have a Northstar model 5500 PPG generator, item number 165911, whose wiring was modified to replace the 120/240V 20A receptacle on the generator to direct wire to a dryer plug (3 wire). I have a new residence and have just had installed an exterior receptacle to plug my generator into (by a licensed electrician) to eliminate the back feed issue. The generator is now to plug into a 30 amp 3 pole 4-wire twist lock connector (male).
I can determine from the generator wiring diagram and from how the wires are configured now as to how to disconnect the dryer plug electrical cord and replace the 120/240V receptacle that was originally installed (L14-20R). Can I just replace the original 20A receptacle with a 30A receptacle, wired the same, and be OK? I would then get a suitable cord to run between the generator and the new house hookup. Other options?
Thank you.
Here is the wiring diagram.
Reply to Portable Generator Receptacle in the UK Electrical Forum area at ElectriciansForums.net
I want to power some load in my house (refrigerator, freezer, a few fans, and lights) with my generator. It is large enough for the loads I...
Hi all. I'm looking for advice on how best (i.e. 1- not a fire hazard, 2- meets code) to connect a solar generator to wiring for an offgrid...
I hope I'm posting to the correct spot. I have a portable generator, Westinghouse WGen7500 (running) that I plug into the side of the house with a...
Greetings, I would like to preface my post by stating I'm well aware of the legalities and danger that are present with this configuration. This...
I recently purchased a steam sterilizer with a PID controller and I'm trying to figure out how to power it safely. The sterilizer requires 240v...
