Discuss Problem with IR/touch light switches in the UK Electrical Forum area at ElectriciansForums.net
C
Chef Hermes
Hi Everybody,
I have several light switches in the top floor of my flat which are the touch/IR controlled dimmer switches.
After having them for 6 months they have randomly started to turn themselves on & off. At first we thought it was a conflict from TV/Wii/AV etc, but more recently they have started to turn themselves off & o when nobody else is in the room.
I was wondering if there is a quick fix or do I need to get a 'Sparky' in?
Many thanks in advance.
Could they be receiving an IR signal from another source/ flat? (Like when I turn my neighbours TV off when he's watching football). They may have a changeable IR code depending on make. Do you know the make?
The first thing I would is reset them and then resync the switches with the remotes, if they have variable settings as Drew says then they should reset to a different value and this may resolve the problem.
Also potentially worth looking at the remote and seeing if the buttons are stuck down a bit and may be just connecting.
I there is a loose connection in one of the switches then the sparking may be enough to trigger the switch. switch off the circuit and remove the switches from the wall and check the tightness of the connections and retighten / remove and replace, if necessary.
Other than that may need professional assistance to test circuits etc.
Reply to Problem with IR/touch light switches in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
My son is having a new house built. The electrical wiring is almost complete but a problem has been detected. Some of the rooms LED lights...
