No quibbles with the regulation. Question I posed was how long it takes to deteriorate. Perhaps its where I live. We have neither extremes of heat or cold. I can only comment on what I observe. I have yet to see visible deterioration.I have to say I'm surprised by this thread, I've seen an awful lot of degraded insulation on pvc T/E exposed to UV radiation over the years. It's a sound regulation IMO, T/E is not suitable for exposure to sunlight.
Of course. And that makes complete sense. But, here's what I ask myself as I look at the electrical industry. Is the UV effect on pvc cable the most pressing issue of safety facing us right now? As you know from my previous posts, I see areas (as I appreciate you do) where there are much more serious issuesDepends on how exposed it is to sunlight also.
Deteriorating insulation on a visible, sunlight exposed cable certainly poses a potential danger which must never be ignored.However it obviously takes place overtime and gives competent sparks plenty of opportunity to remedy it. However I see it as far easier to remedy rather than (forgive me for repeating myself) a broken neutral,which occurs INSTANTLY and for which (to my knowledge) there are no protective measures been taken currently in any country and carries potential consequences likely to be far more serious than deteriorating pvc exposed to sunlight. Hence my previous pointThere are obviously more serious issues yes, but deteriorating insulation is pretty important.
Technically what cable does the Regs say we can use outside without containment because you see plenty of Flex and Hi-tuff but I don't think there in the Regs but manufacturers instructions might say there suitable for outside - do they technically comply?
at OP I have seen T+E outside with little or no deterioration but only very very short runs, long runs T&E outside would probably deteriorate, if T&E became loose and started flapping in the wind it would be damaged Quickly.
There can be significant variation between different manufacturers' products, different batches etc. The problem with using something outside its specs is that you can't predict how it will perform. E.g. one existing T+E might be fine after 25 years and you decide on that basis it's OK, but then the cable you install happens by chance to be less resistant to UV and starts going brittle after 10. Best to avoid the lottery and use materials within their specs.
In housing estate I grew up in (built 1955) you can still see the DSO, s original pvc mains clipped to the facia, s. It may have been just a good batch. Or perhaps the paint helped to protect it?There can be significant variation between different manufacturers' products, different batches etc. The problem with using something outside its specs is that you can't predict how it will perform. E.g. one existing T+E might be fine after 25 years and you decide on that basis it's OK, but then the cable you install happens by chance to be less resistant to UV and starts going brittle after 10. Best to avoid the lottery and use materials within their specs.
[automerge]1597090386[/automerge]Any cable which the manufacturer states is suitable for exposure to sunlight may be used outside. The regs don't specify cable types.
Yes they do technically comply.
It doesn't matter what you, or anyone else, has seen or not seen. The regs are what they are and not dependant on personal experience.
Personally I have seen T&E which is fine after being outside for many years, I have also seen T&E which is disintegrating after a few years outside. In my experience I have seen most common types of cable installed externally and damaged by exposure to tbe elements.
"It does, nt matter what you, or anyone else, has seen or not seen. The regs are what they are and not dependent an personal experience". Did someone hack your account Dave?Any cable which the manufacturer states is suitable for exposure to sunlight may be used outside. The regs don't specify cable types.
When you wrote that statement you may not have intended it to read as it does.In housing estate I grew up in (built 1955) you can still see the DSO, s original pvc mains clipped to the facia, s. It may have been just a good batch. Or perhaps the paint helped to protect it?
[automerge]1597090204[/automerge]
Of course the regs are in reality largely dependent on experience (someone, s). Observable behaviors/effects are still the main driver behind the creating of new regs. We would, nt have a change in the regs regarding the use of T&E in sunlight if people did, nt react to the observable effects of sunlight on it, would we?
In fact to ignore personal experience would be irresponsible
Are you not missing the point here?What change in the regs regarding T&E in sunlight?
