Discuss Replacing old heating thermostat receiver with Honeywell DT92E receiver in the DIY Electrical Advice area at ElectriciansForums.net
ollycro
Hi there,
We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room thermostat with a compatible one. We've purchased Honeywell DT92E (with receiver and controller). Next to the boiler, underneath the programmer, is an existing wireless receiver (Danfloss). This is what we will replace.
The backplate for the old receiver is below.
Here's the wiring diagram on the back of the old receiver:
The new Honeywell DT92E receiver has a different backplate that needs to be wired in. It has a different setup - N, L, L, A, B, C.
Does anyone know if our existing wiring is compatible, and if so, which of the existing wires go in which slots?
Many thanks!
TL;DR
Replacing Danfloss wireless thermostat with a Honeywell DT92E. Need to rewire the backplate as it is different.
Reply to Replacing old heating thermostat receiver with Honeywell DT92E receiver in the DIY Electrical Advice area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Tried replacing Honeywell controller (ST6400C) with Tado wireless v3+ receiver. After switching the power of on, the Tado controller lights up and...
I have a Worcester 28CDi combi-boiler witted with a wireless thermostat which has stopped working. The model numbers are: Receiver 7716 192 005...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
