Discuss Safe Means Of isolation in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
E
electricpawn
Hello all,
Ive just started the C&G 2330 Level 2, year one of my sparky training.
My question is this.....
If i want to replace a faulty light eg emergency light or bulkhead light ie swap a fault unit and put a new unit in place i have to follow a Safe Means of isolation....Can anyone tell me in practice what this means and what is legally required qualification wise and what type of tester is legal to test for a live or dead mains supply ?
i have a C&G in Electrical Engineering but do not have 2330 yet.
Any advice would be greatful.
1)check your volt tester at a known live source
2)check the item you want to isolate
3)islolate power and padlock off
4 Re-check the isolated item
1. Locate the circuit
2. Test your tester
3. Test the circuit is dead
4. Test your tester again
5. Lock off and place warning signs, barriers etc
:D
Reply to Safe Means Of isolation in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
Hello everyone. My name is Ivan, I’m study as electrician on my C&G 2365 level 3. Im a bit struggling with my project. I added an example of my...
Can someone clear up a question for me & tell me to what level I am qualified? ie Electrician/Technician etc? I have the following.... 2360 Parts...
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Electrical Courses
