Discuss Seaward 350 Auto Mode Tests Help! in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
C
CommodoreS
I have got a Seaward PrimeTest 350 and am just trying to get my head around the auto mode tests, and to also make sure the settings for these are correct.
A- Portable/Handheld/IT CLI
Visual Test > Earth Continuity (0.15) > Insulation (250v - 1.00)
B- Portable/Handheld/IT CLII
Visual Test > Insulation (250v - 2.00)
C- IEC Mains Lead 2m
Visual Test > IEC Lead Continuity (0.25) > Insulation (500v - 1.00) > IEC Lead Wiring
D- 13A 5m Surge Protected Lead
Visual Test > IEC Lead Continuity (0.20) > Insulation (250v - 1.00) > IEC Lead Wiring
F- Portable CLI PE Current
Visual Test > Earth Continuity (0.20) > Insulation (500v - 1.00) > PE Conductor Current (0.75)
G- Portable CLII Touch Current
Visual Test > Insulation (500v - 2.00) > Touch Current (0.25)
H- IT Equip CLI PE Current
Visual Test > Earth Continuity (0.20) > Insulation (250v - 1.00) > PE Conductor Current (3.50)
I- IT Equip CLII Touch Current
Visual Test > Insulation (250v - 2.00) > Touch Current (0.75)
My main question is what is the difference between tests A, B, F, G and H, I. E.g. what tests should be used on what type of equipment.
I am presuming H and I should be used on all electronic and IT equipment and F and G should be used on all other non-IT equipment. So what should Tests A and B be used on?
Also should test C be used for extension leads as well as IEC leads and D for Surge Protected leads.
I also wondered if it possible to enter a manual test sequence for Microwaves and how this would be done?
I went on a course, but it was with a different tester and this one seems a bit more complicated. Any help would be greatly appreciated.
Reply to Seaward 350 Auto Mode Tests Help! in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Hello folks, my name is Matt, I live in Cambridgeshire in the UK. I started working for a scientific maintenance company in October as their new...
Kewtech are at the later stages of designing the new MFT, like all the others will be made by Kyoritsu. The new one will be largely based on this...
4K
C
I have a Seaward PrimeTest 350 and noticed these two options in the auto test menu: H) IT Equip CLI PE Current Which does these tests: Earth...
CommodoreS
C
Megger MFT1730 with Bluetooth. Calibrated until sept 2018: Used, but great condition. Comes with all accessories. Wanting £600 Ono Some spec...
