Discuss security flood light in the Australia area at ElectriciansForums.net
W
wannabesparky
can anyone tell me if it is possible to install a security flood light coming from an upstairs ring main as a socket is close to where the light needs fitting but the occupant doesn't want any cables or anything showing outside or the decor disturbing inside in any way.
is it possible to put a fused spur next to the socket and come off that and if so what fuse would be used?
it is a 250w flood light
only just started to take up my college work again.
sensible answers only thank you.
500/230 = 2.17 could even get it on a 3A if you want, I'd go 5A though; plenty for cable (assume youll use .5mm flex or equiv?)
is that ok for a 500w flood light aswell
Someone not listening in here? Eh? Pardon? What?
Let's speak CLEARLY for the chap here........
Simple maths. Simple maths that you learn in the first few DAYS of any college course. You haven't studied for a while, OK, but come on, what have you been doing to forget even the basics? Are you honestly sure you should have that screwdriver anywhere near mains?
230VAC supply. 250 Watt fitting. Watts/Ohm's Law.... V x I = P voltage times current = Power, or in this case - you want to find current, so.... Power, divided by voltage = Current. 250/230 = 1.08A - 3A fuse.
230VAC Supply. 500W fitting. Same sum, off we go......
500/230 = 2.173913A, call it 2.18A = use a 5A fuse for longevity.
Not rocket science.
Reply to security flood light in the Australia area at ElectriciansForums.net
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
I would like to add a flood light camera and outdoor outlet to the front of my house where there is no existing wiring. I plan to get power from...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
