Discuss Setting up the Immersun Vs Central Heating - Help! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You guys obviously don't remember the 70's party trick of shoving a flourescent starter in series with a normal (coloured) 60W incandescsent bulb and creating great random flashing lights for home parties. -- But then no self respecting spark would ever admit to knowing about that trick!
we had lasers and video projectors at our parties....;)
well actually I do remember one party where the lighting effects somehow ended up involving a torch and a christmas baubble being spun by hand.
There was also one party that involved some electrical work on the fly using tin can fuses and plugs being ripped off the decks and them being wired direct into the socket before I erm sorry my friend had to switch to that deck before the record ended on the other deck.... which probably wouldn't pass muster on the old risk assessment. Or maybe I imagined it.
I was running round in short pants in the 70's but have been guilty of occasional iffy electrical lighting effects for the Venture Scout disco in the 80's.
Then I moved to Manc in the 90's and the less said about the electrics in the nurses digs the better really.
Reply to Setting up the Immersun Vs Central Heating - Help! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
