B
BristolMartin
Hi. I am a total novice with no electrical qualifications, but a quick learner and good with DIY and IT. I own a few old arcade machines at home and am having problems with my RCD tripping.
How should I test and what am I looking for?
I have had an electrician in to put a new RCD in to Isolate the building supply where the machines are, it is a RCCB 100A 100MA.
I am quite sure its one of a few games doing it and I have just purchased this: Kewtech KEW 2434 Earth Leakage Clamp Meter
Is it just a case of measuring the Mains plug earth from each Machine? Then in turn each component from within the machine? I am assuming I work backwards from the Building mains and turn on one machine etc and measure. What measurements should I be looking for.
Martin
Martin
