Discuss Simple Hobbyist question in the Electrical Engineering Chat area at ElectriciansForums.net
Short answer is NO,
water (or any mass) at a height is a form of stored energy,
water flowing at speed over your wheel converts SOME of that energy into rotation of the shaft the wheel is on.
you could attach a pump to that shaft and use the rotation to drive it and therefore pump the water somewhere else.
at each of these steps, there is a loss, not all of the energy in the water is converted to torque and speed (power) same with the pump, not all of the power is converted to raise the water, some of it is lost in conversion
so the whole system would need additional energy inserted to make it work, so it can be done as a demonstration but would need a motor or similar to drive it.
p.s. if you do manage to build this magic contraption and it works then congratulations are in order. You will have created the worlds first perpetual motion machine, and you will suddenly become very popular in the scientific community.
Short answer is NO,
Ty James. I'm sure I'm not the first ever to ask. I see vids on 95% efficiency on motors and whatnot and fusion reactors using ideas from the 50's, I'm sure I'm not the first to uneducatedly think of things of this ilk. Still wanna try. Ty again, if I come up with even dumber questions from your perspective I hope you can destroy my dreams of endless power generation in even fewer words than..NO. good times.
P.S. I do understand uneducatedly isn't a word. Ty
I never called you dumb,
you asked a question and I tried to give a simplified explanation of the physics involved.
the one statement you need to remember is
Energy cannot be created or destroyed, it can only be converted from one form to another.
every time you convert it through, you loose some as the conversion is not 100% efficient.
It's cool man, i sincerely appreciate it, if it's not too much bother I'll ask other stuff. I was just watching a vid on russian tanks and wondering why you couldn't put a tungsten needle behind a copper cone (like a panzerschrect, ww2)on a 50. Cal round for penetration into like an APC.
"every time you convert it through, you loose some as the conversion is not 100% efficient."
More correctly, you don't lose it, (as you said, energy can be neither created nor destroyed) but some of the input will be converted to the desired output, the rest (the inefficiencies) will be converted into other forms, and ultimately into heat.
A little pedantic, In most ways the energy converted into noise, vibration, heat etc. Is “lost” in that it has not been converted to the form you require but has escaped and been lost.
if I change £10 into £1 coins at the local shop.
shop keeper takes note and counts out 10 coins but one falls on the floor when I pocket them.
no money has been destroyed but 10% has been lost In conversion.
Reply to Simple Hobbyist question in the Electrical Engineering Chat area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Hi I'm trying to figure out how to swap my standard myson thermostats for WiFi enabled ones - going to start with the simple one first - the one...
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
I'm an electrical engineer in training so please bear with me. Basically, a bank has ordered a second 500kw diesel generator and my job is to...
