Discuss Socket off DB in the UK Electrical Forum area at ElectriciansForums.net
I
ianreed
Dear All,
I am investigating.....
My business has installed over 100 Solar PV installations both Domestic and Commercial.
We also add management systems to out installations that monitor both PV generation and house consumption. We take the spare (free) energy and use it via trickle feed to hot water tanks, plug in radiators, oil filled radiators, slow cookers whatever. They switch on and off as and when there is enough energy to power the appliance.
OK, a transmitter located by the DB communicated with intelligent plugs or switch in the case of the hot water tank. This transmitter runs off 4 AA batteries which last 2/3 months.
Is it possible to spur a socket from the DB (say the ring trip) so I can plug the transmitter in (it has this facility). Or is this a no no.
Thanks in advance.
Ian
Most definately possible!
I would have thought any of the sparkies doing you install connect up would be able to advise you on this? ... and do the work!
Reply to Socket off DB in the UK Electrical Forum area at ElectriciansForums.net
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Yes a friend is trying to get as much low cost energy as possible, he has a water tank with top and bottom elements which runs of Economy7 through...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
