Discuss sockets in stud walls in the Australia area at ElectriciansForums.net
S
sinaloan
do sockets in external stud walls need to be fire rated? also in timber framed houses is it only the joining walls that need to be fire rated? where can i find documents to help me with this, cant find much in document p or bs7671
Additionally, in the adjoining walls of timber framed houses, you must also address the effects on the passage of sound in accordance with Part E of the building regs where sockets & switches etc are installed.
Reply to sockets in stud walls in the Australia area at ElectriciansForums.net
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
