Discuss Spot the mistakes in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
sambotc
[video=youtube;xDl5ooO6k44]http://www.youtube.com/watch?feature=player_embedded&v=xDl5ooO6k44[/video]
How many mistakes can you see in this video?
works fine now...
1. Should have done this install cruciform if possible?
2. Top panel too near the ridge
3. All the rows of panels have the rails to close together meaning there is a large percentage of the panel exposed to wind uplight. So wouldn't be within the panel warantee
4. I don't think any grinding of the tiles was done though its not always necessary
Thats all I can think of but pretty shocking job, might look ok but definately poor installation in terms of the mounting rails
How many times did they move those bottom rails as well!
Can't believe a manufacturer would recommend both rails being within one half of the panel, bet they flap around like nobody's business. (0.54 in the video shows it best)
Not sure why you would use this video to advertise your business on youtube?
I wonder if that really was the last panel to go on aswell, as the bracket is outside the array which I think is poor worksmanship
I wonder if they actually bothered to measure the gaps between the rails and compare to panel width at all!! Terrible overhangs, as above, bet they flap like a tarts knickers (and bang like one too!)
Tiles seem to sit down ok, so that's ok I think. looks close to the ridge, but might be paralax. Sometimes because of joist spacing to avoid excessive overhang the end bracket has to go outboard of the array. I don't like it but have had it a couple of times. Always try to manouver things so it's not in a very visible position. So far only 100mm or so.
We always used to knock a 4"x2" noggin in between the 2 rafters if there was no other way, the contractors we were working for wouldn't have brackets outside the array. Normally only the one right in the eaves which is a pain to fit! Nothing like laying down in fibreglass on a summers day..
What tickles me is the name of the company on the video so you lot can't nick the video and put it on your own websites.
I counted the panels moggy and there was 66 or did I watch it to many times ..plus they were going to fast for my litte eyes to keep up and you hit me with that hammer lasts night...
Reply to Spot the mistakes in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I have by mistake used 6amps C grad MCB on a 2000-watt dishwasher. though I was asked to put 10 amps. but it is running properly. how it is...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Dear Community, I am at the initial phase of my camper van conversion in China, in which I am planning to live and work together with my wife...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
my client has just purchased a 8 kw power shower, i have watched a youtube video on how to run the pipe work so i think i have that figured out...
