Discuss A 2000-watt dishwasher is running on 6 amperes, C grad MCB, how is it possible? in the Electrical Appliances Forum area at ElectriciansForums.net
I have by mistake used 6amps C grad MCB on a 2000-watt dishwasher. though I was asked to put 10 amps. but it is running properly.
how it is possible and is it safe?
thanking you.
If the 2000 watt rating is what it says on the info sticker on the back of the dishwasher then it's the absolute maximum power the machine will ever run at and most of the time the actuial power consumption will be considerably less. Also a 6 A MCB will happily allow 7 or 8 Amps through it without tripping for a good period of time.
All that aside, the MCB is sized to protect the circuit wiring, not the appliance itself. Whether it's safe or not is down to the current rating of the MCB being appropriate for size of the wiring going to the socket outlets.
Reply to A 2000-watt dishwasher is running on 6 amperes, C grad MCB, how is it possible? in the Electrical Appliances Forum area at ElectriciansForums.net
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hey folks Apologies if my question is too basic. I am an Electrical Engineer but do not work in the field. I am looking for feedback to ensure...
