Discuss Spur for diswasher and washing machine in radial circuit in the Electrical Appliances Forum area at ElectriciansForums.net
Y
yarcyk
Hi.
I would like to know if I can connect socket to radial circuit to power diswasher and washing machine (double socket) with fused spur. I know that circuit should be fused 20A so if I use 13A fuse it will probably blow fuse if both working together, can 20A fused switch be used? (I don't think it can but want to know for sure), otherwise what is the best solution to have both appliances connected with fused spur switch above the worktop in the kitchen?
Why are you using radials and not a ring? FCU’s on a ring sit easy with me, off a radial?
Poor / inexperienced workmanship would spring to mind if I came across it.
I think E54 has nailed his colours to the mast regarding radials, well mines now along side it.
I have to agree with the others, iv'e never done a radial in a kitchen unless its dedicated.
I did work with a polish sparks years ago who always wired 4mm radials to do all the kitchen appliances by that i mean one radial serving all of them. I had a chat about it and he thought i was mad as its done all over europe he said. I just gave up.
Please explain why a kitchen radial is bad practice, it is in the brb(or bgb) , I am not being funny, I would like to know the reason why it's wrong
Thanks Spinlondon.
If I use 20A un-fused switch will appliance be protected? But the question remains if I can connect them both to double socket?
Tony, there is a radial in the kitchen and I am installing new kitchen. I'm not gonna change radial for ring as I think the whole installation will need to be updated at some point anyway.
The circuit breaker at the origin of the circuit will protect the cable to the double socket outlet so long as the circuit has been correctly installed. The fuse is not there to protect the appliance just the cable. The appliance if plugged in to the socket it will have a 13A fuse in the plug so no problems there.
Use of the 20A switch should be fine so long as the appliance ratings are not above 20A in total.
Nothing at all wrong with a radial. aslong as you install 4mm2 cable protected by a 32amp in the kitchen. 20amp with 2.5mm2 cable serving the bedrooms and another 20amp radial for downstairs.
Easier to 1st fix(no return to c-unit).Easier and quicker to test.Easier to fault find.Less cables in fuse box to 2nd fix. I think its the way forward. Some sparks cant see past the "ring final circuit".
Obviously i do still install rings but im leaning loads more to a radial circuit. My NAPIT assesor put me on to the idea "why u still messing around with rings" i quote.
I thought we were supposed to radial everything now to save the planet? Anyway exactly what are people using in their kitchens that's using so much? The kettle is the most demanding in my house, 3kw, and that's on for what a minute at a time. I have a large American style fridge/freezer but that doesn't use much. A microwave 800w? On for a couple of minutes. The only thing on for any length of time is the washing machine, and that's only using 2kw when its heating. It sounds like I need to get some more appliances out there, and a couple of plinth heaters to keep up with the Jones.
Washing machine and dishwasher if on at the same time and heating water can be around 4-5kW as both have similar heating elements.
Only for electricians that are ignorant of the benefits and adaptability of Final ring circuits. You design a circuit of any description based on the needs and requirements of the situation, taking possible future needs/requirements into consideration....
Reply to Spur for diswasher and washing machine in radial circuit in the Electrical Appliances Forum area at ElectriciansForums.net
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
