Discuss Supply feed to holiday home in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Customer wants to install a holiday home in one of their fields 300m away. They want a 63amp supply so I just ??
Quick calc comes out at 95mm swa not sure what size drum it would need. I suggested they should ring sse and get a quote for a new supply of off the power pole at the house
Can anyone think of install ideas
63A? Most holiday homes, static caravans of old along happily on 16A…
32 for one of the double unit lodge type.
I suppose, if they’re future thinking of a hottub or car charger at the holiday home, they might need 63A
Complying with 3% volt drop from origin for lighting is going to be expensive or not going to happen!
(It's a I shame we can't go back to the ?15th edition which I think said just the final circuit had to comply)
I'd be inclined to get very rough cable quotes for 300m of 95mm, 50mm and 25mm SWA (for 63A, 32A and 16A supplies respectively). 2 Core and TT might save a bit (I honestly can't remember what section 7 requires for a static caravan). The bonding requirements need thinking about too.
The cable prices alone may prompt reconsidering gas cooking and heating or even a different unit! Two Calor bottles with a changeover valve last a very long time.
I am not up on the current legislation concerning holiday homes, but it used to be that they can only be occupied for X amount of months during a year and not have a permanent power supply, this may have changed since I was involved in this type of development.
That may be true as the suppliers have asked for 63a commando skt so they can just plug in
Realistically 5% is fine these days for LED lighting.
Going TT would save a lot more in cable than it should cost in up-front delay RCD!
Also might be worth looking at larger aluminium cable for same drop but lower cost (Al needs about 50% more than Cu, so around a size up). But remember the serious issues of galvanic corrosion so it might be worth getting some resin filled cable joints at both ends to change down to 25mm copper for ease of wrangling.
For example, using paralleled cores of this 4-core 70mm aluminium stuff:
At the princely sum of £10.18/m + VAT, compared to £19.98 for copper 95mm:
The talk about caravans being used for only part of a year is a license stipulation of the caravan park it is sited on. In this case, no licensed park, so it doesn’t matter.
New holiday homes by people like Wilkerby, ABI, etc make holiday homes to two British standards. Actual holiday homes, and “residential” homes which are built to a higher spec and are designed to be lived in all year.
either way, they tend to come prebuilt with gas central heating and cooking… unless this is being built to a customer spec
Holiday cottage owner here! To qualify as a holiday home (business rates rather than council tax) it has to be available for letting for at least 210 days per year.
There's also a maximum consecutive letting period to one individual or group of guests. I forget exactly how long this is, but a few years we had someone rent a cottage for ten weeks while they bought a house in the area, which was legal. The house purchase fell through at the last moment, so they wanted to stay on for another four weeks, which, strictly speaking, they shouldn't have.
Reply to Supply feed to holiday home in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hello --- In the planning stages for a new custom home build -- The house will be several hundred feet from the road and I want to have the power...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
