Discuss Switch spur behind fridge what can you do in the UK Electrical Forum area at ElectriciansForums.net
Delboy247
I installed a switch spur behind fridge customer was not impressed, but what can you do in this situation I assured him it was perfectly fine, no cupboards next to fridge only way round it to make the fridge sit flush anyone else had a situation like this.
It controls the fridge itself it's not integrated as far as I knew it was a bog standard fridge apparently it's a deeper fridge far better than the others.
Exactly my point when the fridge goes wrong who will disconnect it, I read the manual and it does state you can cut the plug off for this situation
Nothing actually wrong with it as such, other than the customer may feel that if they ever want to replace it, or it needs to be removed for repair/new floor etc., they would then need an electrician to disconnect it.
I know that everyone has their own preferences, but I like to keep sockets in the fabric of the building, so will put the socket either behind the appliance (if there's room) with an isolator above the worktop, or behind an adjacent cupboard and cut a hole in the back for access. I realise these options weren't open to you and you did what was necessary, so you could always appease the customer by offering to disconnect it for free if that's ever required.
I believe it is customary to install the switched fused spur above the worktop, controlling an unswitched socket outlet under the worktop which the fridge plugs straight into.
.... Unless it's a trick question?
I'm guessing that as it's not a built-in appliance, the OP intended to install just a socket, but as the fridge turned out to be deep one, was trying to help the customer out by fitting a SFS instead (lower profile than a plug and socket).
You made a decision that you thought was in the customers best interest , not your fault he has an awkward sized appliance , so dont beat yourself up over it pal.
If you had reason to install it that way it's down to you to explain to the customer why you've installed it that way. You could end up in a massive argument which will end up with you saying 'well if I could have done that then I would have.
All part and parcel of dealing with the general public I'm afraid.
I know that this doesn't help, but I always talk a customer through how I plan to do each job. The number of times I get "oh, I don't want it done like that!", then we manage to find a good compromise, has saved me a world of hassle in the past. Although we are the professionals, and sometimes there are limited options, it is still their home at the end of the day.
I always do this with the position of downlights!
Is there an adjacent cupboard you could put it in. I am not being picky, but this does contravene some reg or other with regard to disconnecting in an emergency, or for maintenance etc. I agree with others, fridges dont go wrong often (unless you IR the ring with it connected like i did) and most self defrost, but you can never say never.
Regards,
Howard
well thats consultation with a customer isn`t it......the same would apply to that imposed on an inspection & test....as in `limitations`....
Rule No. 1 - The customer is always clueless and their wishes / ideas should be ignored at all costs.
If i decide that 32way 400v dis-board is to be fitted above a lounge fireplace its because i've used my highly honed engineering judgement and it shouldnt dared to be questioned thank you very much.
;-D
Reply to Switch spur behind fridge what can you do in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
