- Reaction score
- 5,173
Have been asked to install a little smart camera from nest for a couple. It needs to go on the soffit covering the side of house by the shed/greenhouse as they have had issues with local teens being little gits.. High enough to cover drive approaching and actual shed but not so low the teens can reach it.
There is no power close on the corner of the house and they arent too keen on me pulling floorboards up to access the ring,other than the lighting circuit in the loft there is no obvious source, so whats peoples views on adding a unswitched FCU with 2 amp fuse to power the nest camera?
Seen it done many a time for house alarms siren box but not for a single camera...
The first thing that come to mind was loadings on the existing 1.5mm light circuit but the camera adaptor only draws 0.2 amps ....
A outdoor socket at the top of the wall by soffit is just unworkable as you'd need a big ladder to unplug it.. and the couple are not the most mobile given age.
I was thinking of unswitched 2 amp DCU and cut off the supplied plug and feed cable into the FCU. then this cable has little connection box that a locking usb connects in to feed camera.
There is a video from nest if it helps explain better.
Thoughts welcome? as I am a bit unsure as not had much experience of this new Nest stuff, which tbh looks and seems good quality. Only dealt with Yale cctv before,
