Discuss Tips advice for new build installations in the UK Electrical Forum area at ElectriciansForums.net
J
jamminuk
Hi all,
I was just wondering if anyone had any tips or advice for wiring new build. I've been working on social housing occupied rewires and normal domestic but going for an interview for newbuilds. I'm thinking its got to be easier then occupied, but jus gota watch out for the other trades damaging my wiring.
Cheers
Ben
And don't leave your hobnobs or digestives out or they will go as well. Buggers
Also if you are going to be doing lots of big jobs invest in a tool vault that you can lock up on site, make sure all your power tools, batteries and chargers have your initials etched into them as you will find if there are lots of guys on the same site with the same power tools the gear can get mixed up quite quickly and there is nothing worse than ending up with a your drill and someone's old duff batteries.
Tel agent , don't insulate loft til I'm done there , and if you do I throw all out of hatch . And make sure the plastere/p**ck's don't start boarding untill you've finished and if so let then know in no uncertain terms if I have to take them boards down they will be in no state to go back on a wall unless they're making a mosaic
Allways use metal 35mm boxes when poss
Remember a good 1st fix will save you time on 2nd fix things like noggins for lighting fixtures , dist boards wall lights ext... And coming from occupied's ..... Enjoy except for the usual thing of builder wanting it wired before you've even started itl be a dream
Listen to the builder at all times , if he wants you to cut corners and keep costs down , then do as he says , also don't hassle the builder for money , let the builder or any of his guys mess around with your work , oh and one more thing let them miss use any of your tools as he sees fit , take all this into account and you should get on well ….
Plastic conduit up walls to joists. Using them bracket things for stud walls.
Plastic conduit cutters and tin snips and you will be way quicker than chasing etc when you get the gear
It will prob be dot an dab plasterboard and won't need capping or conduit, just clip it. Any box deeper then 25mm you need to chase in that amount eg a 35mm box needs chasing in 10mm. As already mentioned observe 0.25-0.4 the span of the joists rule for drilling holes.
On new builds the individual rooms are quite often stud walls. Yes the outside walls will be dot and dab though
Cheers guys these are just the sort of tricks of the trade im after. As when ur rewiring all the conduit etc is already in place, never had to put it in from scratch before. Now just need to get the job ;)
Oh also the company specialise in timber frame buildings.
Because a lot of the time they will fill it with insulation and it makes it easier.
I would rather use fast fix boxes as a last resort
What a waste of time that is. As soon as 1st fix carpentry is complete, then 1st fix plumbing and electrics start. I wire it completely before they board it. They pull them through and I cut dry boxes in. I
Pretty much a standard procedure on most commercial jobs to put conduits in stud wall. Use caddy straps to fix them to.
I would always rather use conduit in stud wall with insulation.
It gives rewiring potential, it helps against thermal effects, and a metal back box on a nogging is heaps better than a crappy cavity box any day.
Reply to Tips advice for new build installations in the UK Electrical Forum area at ElectriciansForums.net
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hi guys. I’ve been offered some price work on new build homes installation work. The prices seem quite good, I reckon once I’m up to pace I could...
4K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi Guys I have been following this forum over a number of years reading endless discussions and picking up things along the way. I am a JIB gold...
4K
