Discuss ultra slim LED downlights in the Lighting Forum area at ElectriciansForums.net
Evening all,
A customer has asked for LED downlights in there converted garage but the only problem is there will be only 22mm depth above the plasterboard. I have researched a little and found a couple but the driver ends up needing more depth than the actual light.
Has anyone fitted any lights in a shallow roof space like this or know where I can get hold of some.
Evening all,
A customer has asked for LED down lights in there converted garage but the only problem is there will be only 22mm depth above the plasterboard. I have researched a little and found a couple but the driver ends up needing more depth than the actual light.
Other than round LED panels I think you're snookered.
That's if you can find an after market driver that's slim enough however you then run the risk of overheating the driver as there is no room for the heat to dissipate.
Had this problem myself recently, I used xcite 4w and 8w from CEF and found they were really good. It pained me to use a combined fitting with a non changeable lamp, but sadly had no choice. Worth a look and were a good price
I've used the Enlite small panel lights and the driver will, just, fit in a 25mm service gap.
But in the cases where I've used them I have advised the customer of the likely shortened lifespan of the driver.
Reply to ultra slim LED downlights in the Lighting Forum area at ElectriciansForums.net
Our electrician has fitted these LED downlights: https://ansell-lighting.com/en/products/prism-pro-cct-fire-rated-downlight-dual-wattage Due to...
Hello folks, Just looking for a little guidance please. I am sure that this is something that many of you have come across before. I am...
Hi Forum people. First time post here. I have a pair of semi flush fittings that are currently 10 Halogen capsules per fitting. I want to...
I have a issue with lights flickering in my home. Specifically led lights. I’ve bought a lot of brands of led lights and even most of the...
