Discuss Wallbox EV Charger and Power Meter in the UK Electrical Forum area at ElectriciansForums.net
Has anyone installed a Walbox EV Charger with a Power Meter to enable the Power Boost option? It's installed but there doesn't seem to be any way of confirming that the Wallbox is talking to the Power Meter. I spoke to Wallbox and they couldn't help.
I dont fit wallbox, fitted one but didnt like the screwless terminal for the incoming cable, for something drawing ~32A seemed a bit weak and very loose... that said they are cheap rexel bath have them for 450 inc vat at present! I never get asked for one either...
I consider there to be better options on the market namely hypervolt and zappi.
Reply to Wallbox EV Charger and Power Meter in the UK Electrical Forum area at ElectriciansForums.net
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Hi, sorry if this has already been discussed or is in the wrong place. Im wondering if anyone has come across a domestic EV charger where the ct...
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
