Discuss Wattage or Amperage of Transformer in the UK Electrical Forum area at ElectriciansForums.net
I have seen a transformer rated at 10,000 watts with input voltage of 110v and output voltage of 220v. Can input voltage of 110v and wattage of 100 watts produce the output of 10,000 watts?
What determines the amperage or wattage output of a transformer? The voltage input/output formula is always available but I've never seem formula to calculate the input/output wattage. Any help?
No, it doesn't - the transformer does not multiply output power like that. It will step the voltage up though. This will be determined by the ratio of turns on input side and output side. There will be some energy losses due to heat and so output power will always be less than input power.
leaving losses aside for a minute. the output watts will be same as input watts.so the amperage will be same ratio as the 2 voltages. half the volts and double the amps. and vice versa. obviously, the output wattage will be slightly less than the input, due to transformer losses, e.g heat loss.
Reply to Wattage or Amperage of Transformer in the UK Electrical Forum area at ElectriciansForums.net
Hi, DIY’er here. I need a replacement transformer but can’t find the exact model required anywhere. It is Golden Power GP-SW120DC0700(UK)...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
A potentiometer has a wattage rating of 3 and voltage rating of 100 what would this mean electrically, and how could u transform 25w into 3 watts I'm
Hello, my name is Kelvin. I'm a trainee hydraulic engineer in Indonesia. I apologize if this question has been answered before / if this question...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
