Discuss What has happened here? in the DIY Electrical Advice area at ElectriciansForums.net
So our oven stopped heating up. It's done it before and we had the element replaced. This time I took the back off to have a look and found what, to my untrained eye, looks a little concerning.50625
50626
50627
The wire insulation had turned white around the spade connector and crumbled away when touched, there's obvious scorch marks around the element and it looks a lot like the connector has warped. When I went in the back, the connector had popped off.
What on earth happened? I know what it looks like, but how?
Loose connection between the spade connector and terminal.
it's a common fault. heat damage over time. did one just like that yesterday. cut back wire if possible. fit new spade connectors. the one i did was in a poor state anyway, so client is replacing. i fit on Friday.
in your case use the clean terminal for the new connection. make sure the new spade is thoroughly crimped. the cheapnon-ratchet crimping tools are a bag of shyte. if in doubt, a local spark can fix safely in a few minutes.
Looks to me that it overheated.
We have here some wires connected to a metal object that heats up so much that it glows.
The wires look like they have standard insulation rather than heat proof silicon insulation.
Also, the spade connector is brass which expands when heated up.
This expansion can cause a loss of contact between the female and male spade connectors causing a high resistance joint, which causes further heating.
One other thing to note:
AFDDs do not detect high resistance joints.
Ignore my earlier post. I got the wrong comedy programme completely. It was “the Mary whitehouse experience”
Too late to edit
Too late to edit
adopting a similar scottish accent... "we're all doomed"
The element you replaced it with was of the same current rating? Not a bigger wattage?
Reply to What has happened here? in the DIY Electrical Advice area at ElectriciansForums.net
I was looking for the likes of the SQB1603K and see it is out of stock at CEF and no delivery option available. Odd. Then I search for the part on...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
