Discuss What tests and paperwork? in the Commercial Electrical Advice area at ElectriciansForums.net
bartkusal
Hi, haven't been here for a while.:waving:
Just a quick one, what tests and certificates needed, if installing a couple of circuits, 2A loads from the control panel in the plant room, it will be supplying boilers
Don't say its a full wack EIC , and if I am concerned only with circuits I am installing?
Al
An EIC for the work you are carrying out
Yeah, pretty much new, that this will be the answer, the only thing which is annoying is that you still need to go and figure it out with all the incomers to the building, earthing, bonding ( 22 bonding conductors on MET), sub, sub mains and so on.....uhh:33:
Reply to What tests and paperwork? in the Commercial Electrical Advice area at ElectriciansForums.net
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
Hello everyone i recently got a job on replacing a BMS panel in a plant room. the NEW panel i installed except the control side of the...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
I had just installed a heat alarm on the downstairs lighting circuit during a kitchen rewire. The new kitchen ring / cooker circuit I tested IR...
4K
