L
Lucien Nunes
I don't like the term 'ghost voltage' a.k.a. 'phantom voltage*' much, not least because it's rather loosely defined and probably means different things to different people. I also suspect that quite a few people use the term without really understanding what it is they are referring to.
My definition of what constitutes 'ghost voltage' is quite specific, but first, what is yours?
*OTOH 'phantom power' (as used to power condenser mics and other audio sources via the signal cable) is a different kettle of spooks and very clearly defined.
I'm assuming you're talking about the sometimes spurious voltage readings we can get when testing for dead at various points in a circuit?
If so, I don't like the term ghost voltage... my personal choice is induced voltage because it is induced in the conductors by either induction, capacitance or a combination of both. It could also be residual voltage, from say a capacitor in a capacitive dropper or a filter.
My point exactly. I know what I'm talking about, you know what you're talking about, but there's no guarantee we are talking about the same thing as there's no official definition.
I would not include this under the heading of 'ghost voltage'. It's the voltage due to residual charge in a capacitor, fair and square.
I don't think I've ever use the term Ghost voltage but as S - Chick above, to me it's describing a measured (induced) voltage, but if you connected an appliance to it the voltage would drop to zero.
Not the same as a poor connection / failing switch or isolator where the circuit won't sustain a load, as that voltage comes from a true source.
There's no official definition because the term is too vague, almost Ghostly,,,
Entirely agree. It might take a séance to fathom that one out as it's potentially spiritual.
A few people have mentioned capacitive or inductive coupling, what about resistive leakage into a conductor?
rather than by direct and intentional connection
This is very similar to one of my own criteria for qualifying something as ghost voltage.
Resistive would be a different thing for me,as it would imply some sort of direct connection.
a)-- Not advisable ...
One that doesn't tingle
(turn you into a Ghost if touched !)
But detectable on delicate hang nail flesh.
b)... I would say vanishes with 22k ohm --
or am I not tripping here
c) Disappearing when drummond applied ?
(MFT test impedances are high enough to show phantom voltages)
Aha, an actual number. Not sure what ratio 'vanishes' constitutes so can't convert that 22k into a source impedance, but a step towards my own definition.
To me the distinction between resistive leakage and capacitive leakage seems arbitrary. In any case if one wants to classify between deliberate and accidental sources, capacitance is often built-in but resistive leakage sources are just non-infinite insulation resistance, hence unintentional.
So I need to hunt ghosts with an Oscilloscope , for their " Phase " relationship.
(My status will be spooked)
(or can we even squeeze this relationship out using phase rotation built into some 2 pole testers !)
