Discuss You'll Like This. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Black is perfectly acceptable as a phase colour if its being imported from foreign land to European specifications.
Try the American colour code standard which is often imported here and then has to be wired up.
Cheers ackbar, I didn't know that as well! (same reply as you Strima!)
Are Yank colours Black - L, White - N?
Please expand on "asked to repair". Are you responsible for ensuring they meet BS? You say they are CE marked so are you telling us that they are ok?
With the greatest respect, why have you taken on a job to sort out these units if you are not sure about what is acceptable? Apologies, but I am somewhat confused....
Interesting question. My brief was to make them work! I had no idea what a heap of c**p I had to work on. The customer is clearly out of his depth electrically and he seems willing to pay me to steer him in the right direction. Yes, with a CE mark they're meant to be OK, they're obviously not! But there is no mechanism or requirement to check most CE marked kit before it is sold in the EU.
This is a typical (but the worst I've seen) problem with equipment arriving from outside the EU with an EC Decaration of Conformity. Importers only have to verify that the manufacturer has undertaken the necessary steps to comply which is to do a conformity assessment and set up a technical (safety) file- a paperwork exercise. The importers have no right to see this file (assuming they know what they are looking for) only the HSE can demand that!
So they just accept what they're given and flog it on to an unsuspecting public!
Let regulation 511.1 be your guide here.
1.The Black for a LINE Colour is fine, you could if so wanted sleeve it Brown, but I personally would not bother
2. I've often seen this especially if the piece of equipment is no portable, the logic behind it is that once in situ, who is going to pull the cable ....................but me I would recommend fitting proper stuffing glands and quote reg 522.8.5 as just one to satisfy your recommendation
3. I think you seem to have covered that
4. Perfectly acceptable
The bottom line reg 511.1 is one of these regulations that really does put the onus on you. It basically says that there are so many standards it can't possibly cover them all, so you as the designer or the other person responsible (Love IET speak) will need to make the decision. Is it OK or not.
Reply to You'll Like This. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi forum, A question about R1+R2 testing. I’m testing a lighting circuit. It’s an old circuit with old colours. In the control panel feeding the...
Hello All, new to the forum. Would be grateful for advice on whether the following proposal is an acceptable solution or open to any suggestions...
5K
I want to use a manual change over switch to safely connect a 21kVA single phase tractor PTO powered generator to my mains supply in case of...
  • Locked
5K
I've got a bunch of old single phase BS88 1970s fuseboards in the communal areas of a converted building. All the wiring is MICC and it's buried...
