- Sep 24, 2013
- 1,519
- 2,493
- 3,688
- United Kingdom
- Business Name
- Dovecote Electrical
Eh up
I need a new circuit installed in my house (cooker - it's on a RFC at the moment, naughty naughty), now is a good time to do it as we're going to put new laminate flooring down at some point soon, so we can make a mess of the current floors as long as we can leave it safe. I would also like to put in some new bonding whilst we're at it - there is existing bonding to the water inlet in the kitchen (all good), however we have an additional main inlet into the utility room at the back (yes, two independent main water inlets) which, although not extraneous, I would like to bond as a belt and braces approach.
This is not work I should be doing myself (the new circuit, at least), unless under supervision. It is notifiable work (new circuit) too.
Anyone qualified fancy being a house basher for a day?
I will pay reasonable day rates, the only other stipulations are (a) you agree to let me help, so I can learn stuff, and (b) you agree to notify the work to BC. This could either be through a CPS, or, if you are confident your experience and qualifications will be accepted by the BC, then directly through them. You will, of course, be insured.
I'm in Beeston, near Nottingham.
I can post pictures/take measurements of the lay of the land (e.g. 16th edition split Wylex board) if that will help.
Either post below, or PM me (with rates) if you're interested.
If I get no luck here in the trainee section, I will post a similar message on the main board.
Cheers for looking! Back on line this evening.
