Discuss 2394 & 2395 In Central Scotland. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
E
Emm Eff
I'm looking for venues for 2394 & 2395 In Central Scotland. I know Glasgow Kelvin College does it, but it doesn't suit with dates that I am available.
I've Googled but can't find courses coming up in the next couple of months.
Thanks in advance for any help.
Yeah it is, I was looking at doing a course through one of the members own training centres, but was having to go down to Bradford, Stirling would be perfect for me, where about in Scotland are you?
I'm in Wishaw.
I take it we don't need the latest 17th edition refresher for this course... the 2382-10 is sufficient?
ah ok got you, so will you have to take this first? I'm up to date so I'm ok!
No, I'm up to date. I did the 17th Edition course in August 2009 not long after it came out, and my grade card is 17th edition expiry 2017.
I'm going to book that 2392/5 joint course. It fits with my time onshore and better to get both courses nailed over 5 days rather than 2 separate 5 day courses (although I imagine it'll pretty hefty going with it being both courses).
Sorry did you mean amendment 3 when you said latest 17th course, got you now!
Yeah I think I will look at doing it asap, might go for the September one though will need to work some stuff out!
Yea I meant amendment 3... no way I'm doing that as the 18th edition is no doubt just around the corner.
I'm in the process of booking the September date.
If the exam is failed, how does the resit work... full course again?
Update: Just off the phone to the training guy... apparently the course is over the 5 days, but the exam is later in October when I'm due offshore.
Looks like I won't make it. I didn't realise the exam wouldn't be sat in the same week.
I've just contacted Stow College to see if they do the exam during the 5 day course period. Unfortunately, it will cost more and be 2 * 5 day courses to get both courses done, but I'm governed by my offshore rota.
P.S. I'm glad the training guy mentioned the separate exam date before I paid and forgot about it! Have cancelled the booking...
Update: I'm finding it quite difficult to get information on the actual exam dates. How do C&G expect people to organise time off work to do the course if the exam dates aren't made available?
Is there a reason why exams can't be done on the final day of the course?
Seems a bit bizarre.
2394 exams 13-10-15, 1-12-15
2395 exams 14-10-15, 2-12-15
exams are set by C&G so that all candidates do them simultaneously to avoid people transferring data to others.
Thanks Richard.
I'd need to book extra time off to do those exam dates. I assume if I failed I'd have to resit on the same dates?
Bit of a nightmare this, I thought I'd be doing well seeing as I get plenty time off but it's actually working against me here, although I do understand the reason for the dates.
Thanks Richard.
Unless it has changed since it was the 2391, you won't be able to sit the exam the same day if you failed. You wouldn't normally get your results for up to 10 weeks.
Jay
Jay
Sorry, I meant that resits will happen on a designated day i.e. I wouldn't be able to choose a day that suits me.
I've got this booked for November. Could anyone suggest any reading materials or "mock" tests I should be doing?
You just need to know the basics of electrical installation testing requirements and the entire contents of guidance note three by heart, so it is not difficult!
Just read guidance note three and ensure that you note the correct terminology,
The exam success book has two example papers but the book has not yet been updated for amendment three, however the guidance in there on how to approach the exam can be quite useful.
Thanks, just to recap before I buy...
I need this book and I also need this book?
I assume there's no point in buying the yellow regs book if I buy the guidance note 3? Or, could I buy the full regs book instead? Would there be any advantage?
You would find it very hard to complete the course without Guidance Note 3 (Amd3), though the training centre may have copies for use during the course you would really need to have this as a reference.
The exam success book is just a handy guide to how to approach the exam, giving techniques for answering the different type of questions and explaining for instance that "state" means a few sentences at most, "list" means a list of items with no additions, "in detail" means provide full details, the number of marks available for the question gives an indication of how much information to provide e.g. 2 marks probably means there are two items you need to mention in the answer; if you have only given one item it is not enough to get full marks, if you have a paragraph of text then you have wasted your time.
It is not needed but may be useful.
Go to the City and Guilds website and read the Chief examiners reports about the two exams (under additional documents), these provide feedback detailing where there were common errors and lack of details by candidates; a good list of things to avoid!
If you are operating as an electrician you should already have the up to date regs book as it is pretty much required reading for doing your job!
Reply to 2394 & 2395 In Central Scotland. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi there, This might be a bit of a long shot, but doesn't hurt to try. I'm based in South West London (Richmond/Twickenham) and I'm about 7 weeks...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Hello all, i'm currently employed full time and not looking to change careers (just yet). Id like to train to be able to do domestic...
Electrical Courses
