- Dec 12, 2009
- 3,100
- 3,476
- 144,788
- United Kingdom
- Retired Electrician
When you come to connect up your downlights, you’ll find that it’s impossible to cram two times 1.5mm conductors into the weedy terminal blocks on the lights.Why forget about 1.5mm?
