- May 29, 2009
- 5,067
- 4,421
- 144,788
- 43
- Ireland
- Heavily Qualified Electrician / Teacher / Tutor - etc
- Business Name
- Walsh Electrical Services
Hopefully I've not been too specific with my answer!I know more than I let on, I just didn't want to post something that leads to the OP having a go at anything else.
[automerge]1598473476[/automerge]
Without getting into specifics, the electrode (rod) is mandatory. You MUST have it. It's not optional. But the installation still MUST be neutralised. (Assuming it's not a TT installation - but I can nearly bet my savings that it isn't. TT installations are INCREDIBLY rare within the State and generally are older (or perhaps heritage) installations which haven't been upgraded. That said, even most ancient installations within rural areas (certainly most if not all of Donegal) are TN-C-S.)Thanks for getting back to me, obviously this is beyond me but I'd like to understand so I can have it rectified.
I would suggest that you get a REC on board. You can find one on the RECI website at www.reci.ie or www.safeelectric.ie
I presume you are aware of the scope of Restricted Electric Works - it is a criminal offence for these to be carried out by anyone other than a Registered Electrical Contractor (REC).
What part of the country are you in?
