Discuss Transformer from socket wire to trickle-charge Ring Doorbell - Is this safe? in the UK Electrical Forum area at ElectriciansForums.net
shortie
I have a Ring Doorbell which has no Chime, but which is trickle charged via a wall-mounted BG DIN Rail transformer in a Hagar casing which diverts power from a socket cable. Firstly I have a electric check coming up and I wanted to know if this was safe or is it likely to be picked up in the Electricity Safety check because the transformer is not affixed to a DIN Rail and because in is a BG brand transformer set in a Hagar casing?
It should really go from the socket to a fused connection unit then the transformer on the load side of this. So long as the transformer is secure in the enclosure I would say its ok if there is no damage.
In an ideal world the enclosure would have a cover as I don’t know if that transformer is designed to be exposed in such a way but personaly if its in good condition and secure I dont see a problem with the transformer
A quick search for the CUB1 data sheet shows no specific OCPD requirement.
I would certainly NOT put it on a 32A RFC but have it coming off a FCU with 3A fuse, or off a 6A MCB/RCBO lighting circuit.
Reply to Transformer from socket wire to trickle-charge Ring Doorbell - Is this safe? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
Hi folks, cautious DIYer, so just looking to confirm something. I got a wired Ring for our neighbors who have been without a doorbell at all...
