- Dec 18, 2011
- 5,379
- 6,732
- 405,788
- United Kingdom
Customer has a smeg sy921px8 symphony.
On line it looks like it is 15.8kW, but if you look at the rating plate in the picture it looks like it is less than this!
In the picture it has a squiggle then says 12.5kW. Is this the total rating of both oven and hob? Just seems weird it has the hob rating, then total rating but not oven rating.
The reason for the enquiry is relating to the cable size I will be using, 6mm or 10mm.
