Discuss What kinda wires are these ? [Pics provided] in the UK Electrical Forum area at ElectriciansForums.net
So, my new house is being constructed and I visited it and saw these wires/cables ( orange color, pics attached) . What are these ? What is the purpose ?
Presumably the same as the black ones. My guess would be communication/data cabling?
I'd be more concerned about what is under the tape, is it joined satisfactorily?
They look more like pipes than wires.
are they near the bathroom? Possibly some fancy shower or bath tub?
As James says, possibly pipes. For example, connecting to pressure switches to turn on/off some fancy whirlpool or similar?
I suspect that is tape covering a pipe connector rather than the tape forming any functional part of the joint
Could be yeah. Bit amateur looking though. Mind you some of that framing timber looks a bit ropey!
Ok, so I spoke to the builder and these tubes ( wires ) are for injecting pesticide. There is (outside the house) a small injector opening through which the pest control contractor or homeowner ( if a DIY guy ), will inject pesticide and it will spread inside the wall through micro openings these tubes have.
Found a video explaining the same-
Interesting - I've never heard of that. Thanks for letting us know.
I bet none of us would have guessed that!
Thanks for letting us know because you had us all guessing. Exterminator piping I never would’ve guessed.
Reply to What kinda wires are these ? [Pics provided] in the UK Electrical Forum area at ElectriciansForums.net
Hey everyone, working on a new build house and outside garage is wired up like this, however customer wants a Garage Consumer Unit instead of the...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
