Discuss 3 phase test results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Robo
Currently I put a result for each phase. However I've also seen just the highest reading put and and use up one line of the test sheet. Is this ok?
Many software packages only use the highest reading and it makes the certificate a lot shorter!!!. I did an industrial complex with 12 distribution boards fed from 3 different supplies recently and it still made a 75 page certificate on the AMTECH software. THINK OF THE TREES that used!
Reply to 3 phase test results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
Hello, I’m testing some electric meters. As the circuits have no load on them to prove each ct I’ve plugged a hair dryer to simulate a load and...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
