Discuss alarm cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
dave-gardiner
need to run a alarm cable between buildings 20m apart (agricultural), no vehicular access. do i still have to suspend it with catenary 5.8m in heigh
buried is out of question due to pipe work etc.
alarm cable will stretch and snap if not supported, bt overhead cable has 3 steel strands in for that reason, cant you go wireless ?
Martin
Ask any BT engineer which profession manages to snap or damage the most overhead cables, particularly in rural areas !
Martin
Reply to alarm cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
