Discuss Amperage for lounge & bedrooms in the DIY Electrical Advice area at ElectriciansForums.net
E
Electric_Query
Hi All,
Please can someone help me understand the amperage required for lounge and 2 bedrooms to support normal usage such as lights, tv, dvd player, and the odd 1Kw heater if each bedroom if the boiler breaks down? I have 2 circuits that can provide 20a each. Is that sufficient? Or do they need to be 32a each?
Many thanks.
20 amp will be more than sufficient unless you plan on growing your own 'plants'...
I did a CU change recently, one 32a mcb, for 1 bedroom with 3 x 2 gang sockets.
Talk about overkill
Reply to Amperage for lounge & bedrooms in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
