Discuss Another Wylex compatibility question in the UK Electrical Forum area at ElectriciansForums.net
pc1966
A relative of mine has a Wylex NHRS6606 split load CU (i.e. main switch and one RCD), probably from around 2003, and it is fitted with the likes of the NSB32 MCBs. I don't have a picture of the inside, nor can I expect them to safely do that, so I was wondering if anyone knows if the recent range of compact RCBOs (NHXS1B32 and similar) will fit its busbar?
This doesn't answer your question unfortunately but it's a cool diagram so I thought I'd post it anyway!
Having looked at a few different sites it appears they will
It would be a useful diagram, except that most domestic Wylex boards pre-2018 I've seen have a standard floating busbar, which then isn't quite compatible with the NHX range (and isn't even an option on the diagram)
Not sure if that was people installing with non-Wylex busbars due to availability, or that their diagram is not comprehensive.
It's a ridiculous idea to have two slightly different parts available and then expect the end user to pick the right one. I imagine wholesalers aren't happy about having to stock two types either or deal with the returns.
The thing is, the NHX WILL fit on the standard busbar, but is enough mm out to stop the lid closing, so it's just asking for people to bodge it when it doesn't fit....
It's put Wylex on my list of boards to avoid for years now, but I suspect my non-purchase of 2-3 boards a year is not hitting them hard enough in the pocket to make them see reason!
Reply to Another Wylex compatibility question in the UK Electrical Forum area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Doing a CU change yesterday, having purchased an 8 way Wylex board and 6 Wylex miniature RCBOs recently, and was about to fix the board until sods...
5K
This was prompted by me seeing a couple of videos of cone/step drill being used to make holes in a CU. I use a step bit quite often, especially in...
5K
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
Bear with me on this guys as its a long one and i know these threads have been done to death but im interested in any views any of you may have...
6K
