Discuss Blink video doorbell connect with 12v mechanical bell UK in the DIY Electrical Advice area at ElectriciansForums.net
Amir123
Hi. I have a blink video doorbell and want to connect a 12v mechanical bell (pic attached below). I know Blink only allow 16v-24v AC transformers for wired connection. I know I can attach only a few mechanical door chimes but the one below is preferred as the bell is loud (90db) and I have used it before. My problem is that the transformer to be used is a 24v and the bell will be under power for transformer. 4AA516A3-830E-4619-877B-474188B72B43.png368E19E9-1947-4372-8E34-78EA9D54027F.jpegI have spoken to an electrician who has no idea what to do. Please advise me what my options are from following four questions:
1) would I need a capacitor/resistor in the circuit somewhere to allow power to be adjusted to bell?
2) would I need a second transformer (like a 12v) connected in the circuit somewhere?
3) could I wire the bell into 12v screw for transformer to adjust power to bell
4) could somebody draw out a circuit diagram for wire connections if a circuit can be completed?
Thank you
Reply to Blink video doorbell connect with 12v mechanical bell UK in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
I'm having issues with the new Blink doorbell that I Installed today. Basically, unless the doorbell is wired, it will default to a VERY basic...
7K
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
