Discuss Bosch Oven doesn't want to play in the Electrical Appliances Forum area at ElectriciansForums.net
I took the fan motor off a working Bosch built in electric oven to replace it, and now the heating element does not switch on, though if I switch the mains cooker wall switch I can hear a relay click in the control panel, so there is power going to it. The only two contacts I touched were the motor feeds, I'm mystified, and have no volt meter on site, I would think the oven would work without the fan motor connected ?
What can I check ?
and make sure the timer is not activated.
I had an oven the other week that needed the clock setting first and then after that had to press the select button for approx 5 seconds before it came on. Can't remember the brand, and I thought it was knacked at first until the householder came to the rescue!
Castle Wilko power goes off about once a month. Eventually even the mere male has had to diagnose and fix the "broken" oven. Wifey, well aware, just laughed :) .
What can I check ?
do what i do, fob it off onto the appliance engineer, the time spent tinkering could be better spent elsewhere
I had to go on YouTube in the service station when I picked my van up because I didn’t know how to open the filler cap!
You know what? - it feels better now I’ve share that!
Same bloke who decided that Volkswagen windscreen washer/wipers don't work unless your moving - Thank goodness for google - could've been hours fault finding otherwise.
Well that’s no good to the 70 year olds parked up on the sea front eating their sandwiches with a flask of hot tea! How are they supposed to watch the crashing waves when it’s raining? by rolling forward and back - recipe for disaster that one!
i bought my first automatic and didnt know i had to have my foot on the brake to start it , for a few moments i thought id bought a total dud
i had to ring the bloke i bought my van from same reason. the release is a small lever hidden under the handbrake. only visible from passenger side.
Reply to Bosch Oven doesn't want to play in the Electrical Appliances Forum area at ElectriciansForums.net
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
How can I convert a 3-phase (220 volt 5.6 kw) pizza oven to 1-phase (220) 2 heating elements, no motor.
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
